could this be my problem??
Auto Recall Date: 02/06/2001
Vehicle Component: ELECTRICAL SYSTEM:BATTERY:CABLES
Estimated Vehicles Affected: 120000
2000 MERCURY COUGAR Defect Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH 2.5L V6 ENGINES. THE BATTERY CABLE WAS MISROUTED AND ITS ATTACHMENT TO THE ALTERNATOR CABLE WAS UNDER-TORQUED. IF MISROUTED, THE CABLE COULD CONTACT THE POWER
STEERING LINE AND THE INSULATION COULD WEAR, RESULTING IN AN ELECTRICAL SHORT.
Defect Consequence:
THE SHORT COULD POTENTIALLY RESULT IN A FIRE, STALLING, OR A NO-START CONDITION.
Remedy:
DEALERS WILL INSPECT THE BATTERY CABLE TO THE ALTERNATOR FOR DAMAGE AND, IF IT IS DAMAGED, WILL REPLACE THE CABLE. ADDITIONALLY, THE ROUTING OF THE CABLE WILL BE CORRECTED, AS NECESSARY, AND A ROUTING CLIP WILL BE ADDED. ALSO THE TORQUE ON THE ALTERNATOR ATTACHMENT OF THE CABLE WILL BE CHECKED AND, AS REQUIRED, WILL BE TIGHTENED TO SPECIFICATION. OWNER NOTIFICATION BEGAN MARCH 22, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT FORD AT 1-800-392-3673.
Notes: FORD MOTOR COMPANY, 01S02
or this one
Auto Recall Date: 08/30/2004
Vehicle Component: FUEL SYSTEM, GASOLINE
Estimated Vehicles Affected: 88600
ON CERTAIN PASSENGER VEHICLES, CONTAMINATION OF THE FILTER IN THE FUEL DELIVERY MODULE (FDM) CAN REDUCE, AND EVENTUALLY BLOCK, THE FLOW OF FUEL TO THE ENGINE.
Defect Consequence:
THIS MAY CAUSE ENGINE HESITATION, LOSS OF POWER, SURGING, AND OTHER SIMILAR SYMPTOMS. OVER TIME, THE FILTER MAY BECOME SUFFICIENTLY BLOCKED TO CAUSE THE ENGINE TO STALL, WHICH COULD RESULT IN A CRASH.
Remedy:
THIS ACTION IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN AND IS NOT BEING CONDUCTED UNDER THE SAFETY ACT. ALL OWNERS WILL BE NOTIFIED OF THE PROBLEM, AND DEALERS WILL REPLACE THE FDM WITH A NEW DESIGN AT NO CHARGE IF THE OWNER REPORTS THAT THE VEHICLE EXHIBITS ANY OF THE IDENTIFIED SYMPTOMS. THE FREE REPLACEMENT WILL BE AVAILABLE FOR A PERIOD OF 10 YEARS FOLLOWING THE ORIGINAL PURCHASE OF THE VEHICLE, WITH NO MILEAGE LIMIT. THE CAMPAIGN BEGAN ON APRIL 16, 2004. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673.
Notes: FORD MOTOR COMPANY, 04N02
