Hey Everyone,
I have done a search on this topic, and I just wanted to ask some advice and maybe clear a few things up in my mind. Every once in a while, I am having trouble getting the transmission to come out of park. Now, after doing the search on here, I can add a few more strange things.
#1 - If it won't come out of Park, I can turn the wheel about half way either direction, press on the brake, and 9 times out of 10, it will slip right out of Park.
#2 - It doesn't have this problem all of the time
#3 - Brake lights work fine, IF the engine is running. If the engine is off, no brake lights (is this normal??)
#4 - After crawling under the dash to try to find the brake switch, I believe I found it. Its right at the top of the brake pedal. I noticed that it was kinda "****ed" to the left. I was able to just grab it and straighten it up. It moved side to side very easy, is that normal??
#5 - Ford says my Cougar is not covered by the re-call (its a '99) DRATS!
Ok, I guess I have two questions:
#1 - Can a bad brake switch act intermediate like this? I thought if one went bad, it was bad...period.
#2 - How hard is it to change this switch out?
Thanks for any help and advice, I appreciate it because I am going on a trip tomorrow and don't want to get stranded.
Gregg
Gregg
