Wiring Q: Interior Neons
First off, this is not another question on how to get a wire through the firewall
Now, I've purchased a couple neon tubes for under the dash, and a couple neon license plate frames for nuder the seats. I have the ones under the dash installed, but I don't have the frames yet in the mail, so I'll have to figure out how to mount those later. For now, I'm just thinking, how will I hook these up? Here is my plan, please let me know if there is something I'm missing...
My plan is to join all 4 neon tubes together (pos. to pos., and neg. to neg. obviously) then tap my closed unit with a same guage wire for the ground, and then another same-guage wire that will connect to the switch then to a 12-volt ignition power lead.
Is that it? What about fuses? Do I need those? If so, where do I put them and what kind do I need?
Something else, I went to RadioShack for the toggle switch, told the guy what I was doing, and he gave me the switch. This is what he gave me:
Toggle Conmutador
20 AMP 125 VAC/CA
10 AMP 277 VAC/CA
3/4 HP/CV 125-250 VAC/CA
Do I have the right switch?
Thanks.
Darrell.
Toggle Conmutador
20 AMP 125 VAC/CA
10 AMP 277 VAC/CA
Thanks.
Darrell.
