1 - 15 of 15 Posts
i have access to most wiring diagrams for basically any car...im guessing most are going to want the diagram for the cougar though...these diagrams are for the radio harness to know acc/constant/ground/spkr color and positive negative/ etc.....i also have the diagrams for the colors of the wires needed to install a alarm and info with the pats system...... so let me know by replying or pming me with which one you need and for what year make model of the car....hopefully this helps anyone that needs it:)
Discussion Starter · #2 ·
Re: Wiring Diagrams
ALARM SYSTEM
ALL YEAR COUGAR
Function Equipped Type iC
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
Wire/Function Colour Location/Description Polarity
12 VOLTS Red Ignition harness +
IGNITION Green Ignition harness +
ACCESSORY Yellow or Yellow/green Ignition harness +
STARTER Gray/white Ignition harness +
KEY SENSE Red/yellow At Ignition switch harness +
TACH SIGNAL Brown/blue or Brown/green At engine coilpack AC
LOCK Yellow/green In driver's kickpanel -
UNLOCK White/green In driver's kickpanel -
ARM Black/blue In driver's kickpanel -
DISARM Black/white In driver's kickpanel -
DOMELIGHT / ALL DOORS Black/blue (R) & Black/yellow (L) At anti-theft module -
HOODPIN Black/yellow At anti-theft module -
TRUNK PIN Black/orange At anti-theft module -
BRAKE SWITCH Orange/yellow At switch above brake pedal +
PARKING LIGHTS Red/yellow & Red/blue At light switch harness +
PARKING BRAKE Black/red At plug on handbrake lever -
HORN Black/blue At steering column harness -
CLUTCH SWITCH Black/yellow At switch above clutch pedal TYPE 2
DRIVER WINDOW UP White At master window switch REV POL
DRIVER WINDOW DOWN Yellow At master window switch REV POL
PASSENGER WINDOW UP Yellow/purple At master window switch REV POL
PASSENGER WINDOW DOWN White/purple At master window switch REV POL
HEADLIGHTS Orange/blue At light switch harness +
REVERSE LIGHTS Purple/blk or Purple/orange In driver's kickpanel +
DIMMER White/red At dimmer switch harness +
VSS WIRE White/violet At Powertrain Control Module 8000ppm
TRANSPONDER IGNITION Green/black 4 pin connector (near steering column) +
TRANSPONDER DATA 1 Gray/orange 4 pin connector (near steering column) DATA
TRANSPONDER DATA 2 White/lt.green 4 pin connector (near steering column) DATA
TRANSPONDER GROUND Black/green 4 pin connector (near steering column) -
Re: Wiring Diagrams
Radio Wiring
All year cougars
Wire Function Colour Notes Fuse # Size Location
+12V DC Battery(Constant) Orange/black 36 15 amps Central junction block
Switched Accessory Yellow/green 10 20 amps Battery junction block
Ground Black/green
Illumination White/green
Factory Alarm Disarm Black/white *This wires will also lock and unlock the doors.These wires can also be found at the anti-theft module located behind the glove compartment.
Parking Brake Black/red
Reverse Lights Purple/blk or Purple/orange
VSS Wire White/violet
Pin-58 of 104-pin connector. The PCM is located under the hood behind the power steering fluid reservoir. You can also use a WHITE/BLUE located behind the instrument cluster.
Left Front + White/black
Left Front - Brown/yellow
Right Front + White/red
Right Front - Brown/red
Left Rear + White/purple
Left Rear - Brown/white
Right Rear + White
Right Rear - Brown
Re: Wiring Diagrams
IF ANYONE IS GOING TO ATTEMPT TO DO A REMOTE START CONTACT ME FOR MORE DIAGRAMS THAT YOU WILL NEED
they are pdf and i dont know how to upload them so ill email it to anyone
Re: Wiring Diagrams
Parts For radio installation
1999 and up
Amplifier Integrator Harness
Type Manufacturer Part # Description
Vehicle Specific METRA 705510 1986-2000 FORD/LINCOLN/MERCURY/NISSAN AMP INTEGRATION HARNESS FOR RADIOS 35WATTS AND UP.
Antenna Adapters
Vehicle Specific METRA 40VW10 AFTERMARKET RADIO TO ANTENNA. 06'-07'A3 (w/ Concert radio)05'-08' AUDI A6. 07'-08' DODGE/SPRINTER
Vehicle Specific METRA 40VW30 ADAPTERS FOR CD 06'-07' A3 (w/ Concert radio)05'-08' AUDI A6. 07'-08' DODGE/SPRINTER.
Vehicle Specific Scosche VWA VW ANTENNA ADAPTOR
Vehicle Specific Scosche VWAB VW Antenna Converter
Vehicle Specific Scosche VWAR VW ANTENNA ADAPTER REVERSE
Vehicle Specific Scosche VWA-RB VW reverse antanna adaptor (for factory radio)
Factory Radio Interface
Vehicle Specific VENTURA TECHNOLOGIES VTFDALP12H NO DESCRIPTION
Vehicle Specific VENTURA TECHNOLOGIES VTFDXMPION20H FORD/LINCOLN/MERCURY TO PIONEER CHANGER ADAPTER
Harness-Specialty
Vehicle Specific METRA 731770 Ford/Lincoln/Mercury aftermarket head unit and amplifier combo harness 1986-2004
Radio Antennas
Vehicle Specific METRA 44UA30 AMPLIFIED RUBBER ROOF MOUNT ANTENNA
Radio Custom dash kit
Vehicle Specific METRA 995806 FOCUS 00'-UP, COUGAR 99'-02' SINGLE DIN KIT WITH POCKET. ISO CAPABLE.
Radio Harnesses
Vehicle Specific METRA 711770 FORD/LINCOLN/MERCURY 1986-UP - INTO OEM RADIO
Vehicle Specific METRA 711777 MERCURY COUGAR 99'-02', FORD FOCUS 00'-04'
FACTORY RADIO HARNESS.
Vehicle Specific METRA 801770 FORD/LINCOLN/MERCURY 1986-UP - INTO CAR
SMARTHARNESS
Vehicle Specific Scosche FD02 1986-97 Ford power/4 speaker connector
Vehicle Specific SCOSCHE FD021F Retail harness; full description not available
Vehicle Specific Scosche FD02B 1986-97 Ford power/4 speaker connector
Vehicle Specific Scosche FD02R 1986-97 Ford power/4 speaker connector
Radio Multi-kit
Vehicle Specific METRA 995200 FORD FOCUS 2000, MERCURY COUGAR 1999-UP
Vehicle Specific METRA 995802 95'-08' FORD, LINCOLN, MERCURY MOUNTING KIT WITH POCKET.
Vehicle Specific METRA 995803 MERCURY COUGAR 1999-UP
Vehicle Specific Scosche FM1375 1998 & UP FORD FOCUS/COUGAR ISO KIT
Vehicle Specific Scosche FMC1370B 1998-up Mercury Cougar Kit with storage pocket for disc's
Speaker Mounting Kits
Vehicle Specific Scosche SA68 Convertible 6 x 8'' Speaker adapter (pair)
let me know if it helped or if you have any questions feel free to pm me, i do install on cars for firedog so let me know
So its begun.....
Re: Wiring Diagrams
Send the PDF's to ice992. He can upload the pdf's for forum usability.
On my 01 cougar the rear speakers use grey wires for the negative terminals instead of the brown ones you have listed. The left rear is a solid grey wire but I forgot what the right rear was.
So its begun.....
What year?
Yeah there are about 5 different stock radios, each with a different harness.
Yeah but is it AM FM/single CD, or 6-disc, or CD/cassette, or...?
I'd like to get the diagrams
1 - 15 of 15 Posts
