1 - 2 of 2 Posts
This mabey easier for u to do.
NEON Direct hookup
Here are the directions for hooking up neon lights.
There are two wires one black and one red
The Red wire goes to any 12 volt power source (positive)
The Black wire goes to the ground (negative)
To test the light connect the light directly to the battery.
Run the red wire to a switch - Toggle, headlights, dome light or what ever you can find.
Any basic toggle switch will work.
Run the other wire on the toggle to a power source - Fuse panel or battery.
Just ground the other wire, to the body of the car or to the battery.
Most power sources within the car are already fused.
Good Luck and enjoy
1 - 2 of 2 Posts
