I have a Sony Cd Changer and whenever I change cds or have a gap of silence in between songs I hear a noise that whines along with the engine. I have yet to install my amplifier but I believe that noise will get real loud when I do. I have heard that this happens when you don't separate amplifier power and rca cables, but I know this can't be the problem, because I don't have an amp yet. Does anyone have an idea of what is causing this?
-Rob
Line noise isn't only caused by the amp power wire. It will be caused by ANY power wire. Check to make sure that your speaker wires aren't up against a power wire. If they are, and you can't move them - just wrap the wire in electrical tape... That should help the interference a little. Besides that, there are also other things that create the whine... Do you have aftermarket indiglow guages? These will create a whine when turned on if not grounded correctly. Also, as was said - try to groung the stereo somewhere else. Maybe you have a bad ground. If all else fails, you can go to radio shack and get a line noise reducer - but they don't really work that well. Good luck!
i am not too sure about the hook ups between the head unit and the changer but if it a type of RCA cable and not like a patch cord you may want to try switching to more shielded thicker cable...definately check your head unit ground though...
