1 - 15 of 15 Posts
if you are talking about calibrated MAFs, I would sudgest doing that as the last mod. IMO it will only provide a noticeable gain after other mods are done.
My .02 cents...
I only plan on getting one after I change everything I want to change enginewise.
thanks, i just posted this, because i heard that 80mm MAF doesn't need to be programmed no matter what mods you have or even if you add a new, but i heard also the 75mm gives more gain,the only problem with this one, it's needs special calibration
I still say that a calibrated MAF would be done as one of the last things (except for a chip). If you want to get it now, I would at least optimize the intake. Save up and get SVT intake manifold and TB, then a CAI... why not just getting an exhaust??? from your sig it seems like you dont have one.
One question, isnt the 80mm MAF the one from a mustang? If so, didn't it actually produce a loss? I remember something like that on the boards way back in a day...
Discussion Starter · #11 ·
yeah,i heard the 80mm is too big, but i just trying to get some cheap hp, i just bought the shop shop Y pipe with no cat, and i'll gut the precats also at the same time, i just don't 400 dollars to spend in exhaust for now, but i will.
The Y will free up some flow, but the stock rear muffler will still be a little bit of a restriction. For like $40 you can get Mineky to swap out your rear muffler with a straight pipe, and then youll almost have an aftermarket system :shrug:
tell the truth i didnt really feel a difference after my duals
I recommend you read this post. MAF upgrades are a waste of money unless you're in the top 5% of mods to your Cougar.
Mass Air Flow Meter Sizing
Meter Diameter Maximum Recommended Horsepower
55mm 320
70mm 380
80mm 485
75mm Bullet 600
87mm Bullet 650
77mm Pro M 700
80mm Pro M 800
83mm Pro M 900
92mm Pro M 1000
117mm Pro M 1500
So as you can see your fine with what you have right now.
1 - 15 of 15 Posts
