1 - 12 of 12 Posts
Just need to know where it is so I can run a T fitting and install my autometer temp sender.
Also where can I get this tee fitting and what size?
I found Atlas's pic of what he used in a search, so hopefully thatll work out.
Between the heads, under the throttle body, beneath the fuel line(s).
...and it looks like this:
Brian with the SCOOOOOOOORE!!!!!!!!!!!
Do I get credit for the assist on that one?
BTW, the one facing RIGHT is the ECU temp sensor; the one facing down (the broken one) is the temp gauge sensor.
I thought you was getting the credit and i was getting the assist?
But if you want it the other way around i'm all for it! :rofl:
FINALLY :)
Wow...2005 thread :confused:
If you have a 2.5L. The temp sensor is on the drivers side of the engine bay...located in a molded plastic housing. It should be located just below the aluminum thermostat housing...it is not too hard to find.
1 - 12 of 12 Posts
