1 - 20 of 39 Posts
here u go adam here is some pics of the install and of what the old stuff looks like. this install was a pain in the @$$ . I purchased the SPEC stage 2 clutch and SPEC lightened flywheel. sweet package and came with a throw out bearing.
i was driving to work downshifting to pass someone and the clutch pedal stayed on the floor luckily i was only going 45 , i was able to get in neutral and slow the car down. the clutch didn't feel any slipage or anything. just boom dead
here is the install pics
remember to support the engine from the top
lift her up in the lift
pop the axles
support the rack and pinnion so it does slip out of the column, and bend all lines up. that would be bad.
drop the cradle, have fun with that
remember to support the transmission from underneath so u dont kill ur top motor mount
pull tranny apart from engine
look at the damage
WHAT YOU DO NOT WANT TO HAPPEN.....VERY VERY BAD AND EXPENSIVE
what a flywheel is not supposed to lood like , kinda hard to resurface.......gotta get a light weight one
INSTALL NEW SLAVE CYLINDER (came with the kit...... :D)
the goodies that came in my package.....
SPEC 9lb lightened flywheel
SPEC stage2 clutch
and the clutch installed in my baby
this install was easier for me because i had the lift and air tools. i cant believe it when i hear about people doing it in there driveway, unless u pull the entire engine out of the car
Excellent post !
Thanks so much for those pictures. I recently had my clutch replaced but it's nice to see what it actually looks like apart when you do it yourself. If only I had the time. Anyway, great post again !
i am trying to push as much i can out of the 2.5L and I do plan on using a built 3L and i felt better using the ss2 than the ss1
Discussion Starter · #8 ·
i wish she still had more miles. the slave cylinder crapped out really bad. the pedal was on the floor and i had to pick it up off the ground with my hand and it would just fall back on the floor. i have to rebuild the tranny or just do what predator is doing and get a second tranny and rebuild that one and then just swap
· PLATINUM M0DERAT0R
Oh man, you are a life saver! I was going to swap it out this past weekend but couldn't figure out how to support the engine and pull the subframe.
We have airtools which will make it easy, but this works out perfect! I'm taking pictures of everything also. I got great documentation on how to install a Torsen LSD with a video clip of it spinning in the tranny.
Discussion Starter · #10 ·
thats why i posted it :thumbsup: one here should it get stickied?? :confused:
Discussion Starter · #11 ·
cool cant wait to see the video and the install on that. we want that so soon.
Discussion Starter · #16 ·
yep this is true . i just replaced my trans with a rebuilt one from terry haines( HMS)
and yes i just repeated this process and i just endured the suck..again . I just cant bite the bullet and pay 500 to have someone eslse do it
i must add remember to be careful with the shifter cables when removing them from the transmission because they are expensive.
how long did it take you to do the whole thing? FYI if you learn the duratec quite well you can pull it successfully in 4 hours, install the new shizzle, and then another 4-6 hours of reinstalling
Discussion Starter · #18 ·
if we had all the right tools we would have done it a lot quicker ,but it was a lot quicker than the last time
Discussion Starter · #19 ·
this was stickied?
Discussion Starter · #20 ·
should this be stickied again? on fastcougar it was?
1 - 20 of 39 Posts
