4441 - 4460 of 4487 Posts
Got the Cougar back from the local garage that took 3 months to replace the clutch last week and finally got to drive it.
They didn’t hook up the fan ground so it overheated while in traffic.
They screwed up something when bleeding or installing the TOB so it failed while in traffic.
It lasted 170 miles and I waited 6hrs for a tow truck.
Murder should be legal.
That's terrible! The offer always stands if you want to use my mechanic again where you can park it in my driveway temporarily while you wait for it to get taken care of. He did up the hourly rate from 60 to 80 in the past year but he's still quick and cheaper than most. Most importantly very reliable with quality of work, and he let's me bring him whatever parts I want. let me know if you need to tear into it again.
Repaired the engine, then went out on a test drive to find I had no brakes. RR caliper was puking fluid, and LR caliper was seized. Out of 6 star mounting bolts on both calipers 5 were stripped at the head. And of course both hubs were shot. Had to grind off bolt heads and weld nuts on, torch a ton, or cut the caliper brackets off the knuckle with a grinder. So I did a complete rebuild on both sides. Replaced all star bolts with 10.9 hex bolts. Blasted the shields and powder coated them, then new hardware everywhere. Sanded new calipers and coated with Por15 high temp matte black. Even spent 40 bucks a piece for new grease caps. This spring i'll put on new struts/springs and upgrade the rotors while im replacing EVERY SINGLE BUSHING ON THE CAR 🤬This car is a labor of hate and love so far.
Automotive tire Motor vehicle Vehicle brake Crankset Vehicle
· Moderator
2001 Laser Red V6 ATX
· Administrator
Great work. We’ve all been there.
  • Like
Reactions: SpaceCatsAZ
· Moderator
Got the emissions checked on the Cougar yesterday. Continued the biannual tradition of the tech not being able to get the OBD plug in place and doing it for them. Also continued the tradition of them having to get the manager over to approve it for some reason (related to the new engine I think).
Passed, though, and good for two more years.
  • Like
Reactions: wadespencer99
· Super Moderator
Went to fix one simple thing in the engine bay and found that my drivers side upper trans mount bolt was broken. I have extras, but im not sure how it happened with the front mount being metal, and the rear being completely filled. it doesnt move
· Administrator
Laid this beauty in today -
The car is about 90% there. Next up is a big TCE brake kit, whenever I get it tagged and insured, and that might be the limit for a good streetable N/A 3.0 build.
· Administrator
Rule book for XS is pretty silly; I don't anticipate any issues.
Weight actually doesn't seem like an alarming difference; I didn't weight them, tbh. I think the glass is half of the weight, honestly. Time to find some lexan...
· Administrator
It is not sitting as straight as I want it. I tried adjusting by looseining the bolts that hold the hinge to the lid, and it doesn't seem to want to move that way. So maybe there is some give in the bolts holding the hinge to the body; that's what I was going to try next, it just involves dropping the headliner down again though.
Otherwise it closes and latches just fine.
Back on the subject of weight though - it does raise up MUCH quicker on the trunk struts though, so it is definitely a lot lighter than the steel one. Maybe one of these weekends, if the weather cooperates, I'll unbolt it and put it on a scale. Because I'd love to know exactly.
· Administrator
On his I really had to slam it to get it to latch, and then it still sat up higher than the quarter panels on either side. It was also too far back, so I had to oval the hinge bolt holes out to be able to slide it forward. That fixed that problem, but I never got it closing quite right. Because of the fiberglassed stereo install in the hatch I couldn't get to the latch itself to see if I could adjust anything there.
I'm glad you didn't have as many problems.
· Administrator
Was checking TCE to make sure they still had their big brake kits for sale. Did not realize their Cougar kit uses 6-piston calipers; wasn't it previously 4-piston calipers? Maybe that's why the price shot up so much...
Once I pull the trigger on this, it will be the most expensive piece of this car - INCLUDING the car itself, LOL
· Administrator
The TCE Focus kit uses the 4-piston calipers, but the Cougar/Contour kit clearly specifies a 6-piston caliper.
