BIG DAY.
Pulled the fuel tank and EVAP system off the green car. Started pulling the electrical connections - and it ended up taking all day, because there are no disconnects you can pull on those wiring harnesses. So had to remove the dashboard to get the last of those huge wiring harnesses loose in one piece. Both sides of the car, back to front and side to side. Massive H-shaped harness with dozens of connections and plugs and ground straps and grommets.
I had planned to do this work in stages, but things have changed. Now it’s one huge job instead of 3-4 smaller jobs.
Next step will be to put the returnless fuel system in the silver car, and lay in the body harnesses, and try to get the dashboard wired up.
Next after that will be to drop the power train out of the green car and finish removing all the wiring in the engine bay, along with the fuel lines and EVAP lines.
Tick tock.
