what can I do while tranny is out of car?
Do you have to pull the engine in order to get the tranny out, and if so, might that be a good time to do a cam swap? I have a set of SVT heads and cams sitting at home doing nothing and although the heads need a lot of work and hopefully a port and polish before I try to throw them in my car, would it be feasible to do the cam swap now while the engines out of the car because of the tranny?
If it's possible, what would I need to make an SVT cam swap into a 2002 returnless V6 MTX. I'm thinking SVT ECU, and as a result, 19bs injectors, and SVT MAF and MAF sensor, as well as the cam timing chain I'm assuming? Is that it or would I need more then just those items?
Is there anything else I should try to do while the engine is out short of separating the heads from the shortblock? Any ideas would be greatly appreciated. Thanks.
Adrian
Adrian
