ive never been more scared in my life driving my car today. It has been perfect for the past year with no problems at all... then today it went hay-wire. I went back home and parked in the driveway. I come out an hour later to leave and my car is completely dead.. i turn the key to start the engine, the gauges lights flicker on and off and the needles sweep... i had to jump start it with my mothers car. Ok, all is good i thought the battery some how drained.. Im driving on the interstate, and i notice everytime i hit the brakes my car dies. It just flat out loses all power, the gauges turn off, the music turns off, my radar is gone, and the engine bogs and dies... i let off the brakes and the engines jumps and restarts and everything comes on and works...
So as you can see, everytime i touched the brakes my car would die, and i had no idea wtf was going on... i basically cruised at 45 mph on the interstate in teh far right lane as if i really died id be able to pull over... and i had to use my parking brake to stop to get home. Ive also discovered when i turn my headlight switch on it does the same thing as if i push the brakes... now my car is completely dead out front of my apartment, it has no power to even turn on accessory. What is going on here? How can it do this when i play with the brakes or lights? Anyone know?
Re: WEIRD electrical problem... car dies while driving
Is the car running fine .. perfectly fine when you dont press on the brakes or use the lights? or is it bearly runing?
Its kinda hard to diagnose. If it was just the brakes while going down the road and brakeing hard, id say its a loose ground. If its just the fact your using too many accesories on a half dead alt, then its the alt.
Having the amperage tested at AutoZone or where ever would be the next step in diagnosing the problem. Kinda would like to know what Amperage your runing at, not so much your voltage, though that would be nice too.
Start w/ the obvious things. Are the batt. terminals clean and tight? The fact that your gauges will randomly sweep means there's a break in the circuit every bit of time and the gauges reset themselves.
Make sure that none of the battery leads are close to the hood. It would explain the issue with the braking, but not the headlights, that when you hit the brakes you are shorting the car out with the lead hitting the hood.
You could also have a bad tensioner, which again would explain why you would only have issues when breaking, as the engine is revving down and the belt would loosen at that instant time point, causing a serious of events to happen that would turn the car to dieing. Yes, a simple belt slip can basically kill this vehicle with it being a single belt driven car.
Another question, that might help but is only very slim in helping would be, was it raining when this was all happening?
Have you checked that all the fuses in the under the hood fuse box are good?
Did you replace the battery, since you mentioned the possibility of it being a battery issue from the beginning before jumping it?
yeah, the car runs fine without the brakes / lights on... i use the AC... the radio, windows... all is fine. But the thing is, after i arrived to my apartment and turned the car off, i went to turn it on 2 seconds later... DEAD... what is the deal here? i have an optima yellow top
Either your Alt is just bearly keeping the car alive and not charging the battery at all, which i think is the case. OR you got one of those bad yellow tops, there was a bad batch about a year or 2 ago.
You can take the battery to be test it, or charge it up at an auto zone?
matter of face the battery was bought around 2 years ago... but i dont see how it can be the alternator. I havent had any problems leading up to this.. its just perfect one day, the worst the next. But ill have to get a voltmeter out and find the charge on the battery, how can i test the alt?
you test the alt by having the car running and use the voltage tester on the positvie and negative terminal,if the reading is more than 14 amps your alt is charging the battery, if it is lower than 12 your alt is not charging the battery
Actually thats mostly untrue. Voltage is a decent indicator but not a true one. You can have an alt runing at 14v but not producing the amperage needed. To test amperage you will need an amperage clamp. Most people dont have one of those, but any autozone, pepboys whatever will test it for free by putting a camp around the battery cable.
I would bet on the alt... mine just dide again. Freaky weird things happen when the alt goes bad. Get it checked at an auto parts store, and you can get an alt there too, and put it in yourself, or have a shop do it. Just get an alt there, DO NOT let the shop get you one for way more, unless you get a lifetime warranty.
which wire would this be? i plan tomorrow on checking on the braking wires underneath my dash/pedals and have a closer investigation in the engine compartment. the real problem is jumping my car to get to to autozone to have it tested.
ok so i played around with the car today.. and i found out some interesting things... When i turned to accessory via the ignition the gauge cluster would reset and the ligts would very dimly illuminate and flicker, no other accessories would work such as the radio / radar / windows... but i left the key in the on position for a minute and magically everything worked again. the lights came on with full power, i could play the radio, the radar worked, the sunroof / windows worked, the ac would turn on.. well i just put in on to blow... the brakes worked.. BUT if i touched the headlight switch or the high beam it would COMPLETELY die... all lights went off, even the miles / time on the lcd display on the dash. I searched as much as i could for faulty wiring under the dash and in the engine bay.. nothing.
I tried to replicate this again but i couldnt get it to happen, but i did notice while the key was on and i ran to my engine bay i could hear two ticking noises.. but couldnt tell where from. IT also seems to me that my engine belt is really loose. So now im wondering.... how the hell did my car get full power for those 4 minutes and not work after i turned on the headlights... as a note, before i turned on the headlight i tried to crank the engine to see if it would start, it just clicked once and that was it. Im baffled here, what in the hell is going on?
Some of that is the added properties of a yellow top deep cycle battery. ... but anyway your battery bearly has any charge at all. Still think the alt isnt charging it for what ever reason.
The main wires to check are the leads coming down off the battery terminals. Mine were rubbed to bare metal when i went to put in my CAI 2 years ago. And theres a recall about badly ran battery wires that effects a small % of cougars.
Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH 2.5L V6 ENGINES. THE BATTERY CABLE WAS MISROUTED AND ITS ATTACHMENT TO THE ALTERNATOR CABLE WAS UNDER-TORQUED. IF MISROUTED, THE CABLE COULD CONTACT THE POWER STEERING LINE AND THE INSULATION COULD WEAR, RESULTING IN AN ELECTRICAL SHORT.
Consequence:
THE SHORT COULD POTENTIALLY RESULT IN A FIRE, STALLING, OR A NO-START CONDITION.
Remedy:
DEALERS WILL INSPECT THE BATTERY CABLE TO THE ALTERNATOR FOR DAMAGE AND, IF IT IS DAMAGED, WILL REPLACE THE CABLE. ADDITIONALLY, THE ROUTING OF THE CABLE WILL BE CORRECTED, AS NECESSARY, AND A ROUTING CLIP WILL BE ADDED. ALSO THE TORQUE ON THE ALTERNATOR ATTACHMENT OF THE CABLE WILL BE CHECKED AND, AS REQUIRED, WILL BE TIGHTENED TO SPECIFICATION. OWNER NOTIFICATION BEGAN MARCH 22, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT FORD AT 1-800-392-3673.
Yep, just a small % of cougars, potentially only 120k of them, but you know a small %. :biggrin:
You should be able to schedule a time with a local dealership to check into all the issues that have come up for your years car, free of charge to you.
Potential means they dont know how many. And before you be a smart ass maybe you should ask around. I know of one neco member that the dealership agreed this recall affects thier cougar.
It doesn't matter of the word potential. The risk of their being an actual problem is what is at issue and for only one NECO member having the dealership claim that is the cause of a problem they are having, that is good. Meaning, most of the NECO members have either visited a Ford dealership and got something done on their vehicle. Or they follow recalls for their vehicles and have gotten this taken car of.
I have had this recall done on my car and it has stopped an issue I got with the power steering going out intermittently.
I'm not being a smart-ass, I was just pointing out the large amount of cars this could have potentially affected. Being that for how few cougars seem to be left driving around the US these days, 120k is a large chunk of the '99 to early '01 range, if it indeed affects any '01 cougars. Which I would say no, since I do not see a recall for the routing of the cable on the site I'm looking at.
Smart ass or not your giving bad and false advise. Most likely if he takes it to a dealer they are not going to agree this is part of the recall and want to charge him an ass load of money. You may have a nice dealer in your area, that is not the case in most of the US. IT WONT BE FREE.
Under the Safety Act, Ford is required under law to provide this repair free of charge as it is harmful to not only the person(s) in the vehicle, but to those around them if something bad were to happen. Yes I had a nice dealer service manager to handle getting the fix taken care of without me asking for it, but no matter if he asks for it or not, it should be taken care of for him free of charge. If the Ford dealership does not fix it (because they want to charge for it), after he has asked for the repair, and something happens, he can rightfully sue the Ford Motor Company for not providing the repair in a timely fashion without charge to the owner. If you don't get the repair for free. First, don't approve for the repair. Second, call the 800 # above and follow whatever prompting it asks you to go through.
As much as you want to call me a smart-ass and say I'm giving bad information, please show me what I'm saying is wrong, other than the dealership not making a free repair for the guy on a recall. As what I quoted above is the actual recall from Ford.
ok, next chance i get ill take it to autozone and get the battery load tested and also tested to see if the alt is working.. according to those results ill decide if it has to go to the dealer. either way sounds like im out lots of money
Youre soo clueless. Ok
1 odds are extreamely small that this is actually whats causing his problem.
2 Being that its probably not the issue they will most likely insist on at least a service fee.
3 and from there if he chose to have it fixed there it would be costly.
Youre basing everything on the slim chance that this recall actually applies to his car, which theres about a 1 percent chance that it does. That 1800 number wont do you a bit of good when the problem doesnt even apply to the car. Given those kinds of odds its an awfull bit of advice. But whatever keep typing.
Re: WEIRD electrical problem... car dies while driving *update help plz?
well update, i tried to examine this more. the car is definately undrivable and ill have to get it towed. It seems now like all the electrical works such as headlights, etc which didnt before. BUT now my brake / brake lights are completely shot. I have the key on on mode and i push on the brakes - no lights. so i got a jump and i push on the brakes with the engine on, and it doesnt release the safety switch so even if the car is started i cannot put it into drive. So somehow the entire braking mechanism is disabled, i failed to check fuses tonight but this is weird. By the way... my engine's belt is INSANELY loose. So after the car was on for 5 minutes i turned it off and tried to start it back up again, and it was dead. could the alt not be charging back the battery? I mean i can atleast stretch the belt a few inches... and i never remember it that loose.
Re: WEIRD electrical problem... car dies while driving *update post 25
Yes it sounds like the alt isnt charging the battery at all, which could be the dead alt or a dead battery thats not able to accept a charge.
Normally most car specs say there should be about 1/2 inch of flex in a belt. I forget exactly what the cougar spec is. But that sounds like way to much. SO either the Belt is bad, the tensioner is bad, or one of the pulleys is totally messed up and massively out of place. Or the belt is just off one of the pulleys.
You should be able to at least see the entire belt and its path on the left side of the engine. The tensioner is right in the middle, about. IF you can reach down and move that tensioner with your hand, its screwed.
everytime you post the problem seems worse lol. sorry.
ok had it towed after a month of not moving, for the hell of it i swapped out my optima yellow top with another spare battery of mine. works. everything works. No more electrical problems, starts flawless, no voltage drops... So problem solved. The next thing i want to know is how my optima died in under 2 years time...
Im glad its just a 60 dollar battery replacement and i didnt have to take it to ford to get that diagnosed.
check you feeds and ground to your brake lights. if it grounds out it will short ur car out what ur applying the braks which is sending a current to the brake lights....These are failures in a curcuit
These can all cause ur battery to die
1.short to ground
2.short to another circuit
3.short to voltage
4.open circuit
5.unwanted resistance
If the battery was the problem then there must a been some corrosion or something internally going on in there and when u braked it just drew to much current that the battery didnt have...Do you got rough roads with rough/stiff suspension you can vibrate the hell out of the battery and cause internal break up and when u brake u could be shifting the battery acid and what not causeing a short? also u dont boost ur car directly ground to battery ground do you u should use a chasis or engine ground. You can fry or worse cause ur battery to explode...I took a $5000 coarse that GM who i work for paid for
i took my optima out and back to autozone where i bought it. they tested it. only held at 2.1 volts. they laughed and said it was one of the lowest charges theyve ever seen a battery hold. 5 minutes later i was out of there with a brand new one at no cost. the first optima i bought on 11/13/04, just over two years ago. Put in new one, runs great few days later no problems still.
