Or you can spend that $100 on beer and entertainment, because it will only take you ten minutes to install it yourself.
The template is a HUGE, folded, paper. On the paper you see the triangle for where the scoop goes, and the top T that lines up against your hood, where it meets the windshield. Use that T and cut it out, you don't need the extra paper, it only gets in your way. And with all the extra paper around the V part, you can't really line it up correctly...so use the V and T as guides, and cut it out.
I used scotch tape to hold the template on the car, and used my eyes to line up the scoop. Then I adjusted the template to fit exactly where I wanted to drill the holes. Then I re-taped the template so it would not move what so ever.
Open your hood and lay a peice of ply wood on top of your engine. While drilling through the hood, I knew that I would thrust the drill past the hood when it finally cut through it, I didn't want to hit the UIM or any hoses.
Now simply drill according to the template and the proper drill bit size. Remove the template, lightly blow away all the slivers of metal. DO NOT wipe them away, that will leave scratches on your hood.
Now, if you have any color Cougar, OTHER than black, you might want to do what I did. After seeing a lot of scoops on light colored Cougars, the one thing that I couldn't stand, was being able to clearly see the hood under the scoop, through the mesh. Having a laser red Cougar, I did not want to be able to see red under the scoop. So I put down some black vinyl on the hood, under where the scoop was to go.
Then I slapped the scoop on, and insetred the screws. All in all it took me 10-20 minutes to completly install.
