1 - 2 of 2 Posts
I was wondering what kind of adhesive to use when reupholstering the front and rear panels. i have some spray adhesive i got from the fabric store. will this work????
The spray adhesive will work, but make sure that you follow the direction for a permanent bond. Most likely you will have to spray both surfaces, wait for it to dry a little so it is tacky, then joing them together. If you just spray one surface and then stick it on it will fall apart within days. Otherwise, for a really good hold - Stinger car audio products makes a spray adhesive for carpeting boxes that works awesome. It is more like a web effect when it comes out of the bottle so it is alot less messy and it is super strong! It is about $7 a can.
1 - 2 of 2 Posts
