vehicle speed sensor location?
1195 Views 5 Replies 3 Participants Last post by  painteddemon
any one know where it os on the 99 i4 xteck atx?
I can help you with this, but what the hell is an "xtech" atx???
You have a VSS feed off the back of the stock radio. It's on the harness with one wire. Just tap that one.
oops so i typed ot wrong u knew what i ment 99,i4,zteck,atx. i need to know where the location of the vss is so i can change it
You should see the VSS on the side of the transmission if you take off your drivers side tire.
Edit: and it's ZETEC
i know if u do that thats where the tss is but is the vss somewhere in there to?
