1 - 3 of 3 Posts
Good day folks. I surely hope someone out there will be able to assist me. You see I've been working on a check engine light for quite some time to finally realize that I had a bad vacuum leak. It was due to bad seals mounted at the end of these vacuum line you see in the picture. I tried "O" rings but due to their shape will not stay in the groove designed for the seal. So I ended up using vacuum connectors with a piece of hose. It works but I'd rather have it as the factory intended. So any ideas of where I may locate those seals? Thanks in advance.
Discussion Starter #3
you can try ford, but im guessing they are discontinued. i know there are some members that have tapped brass 90* fittings into there for something that is a bit cleaner that what you have.
Thanks so much, I'll have to go to the plumbing store to see if I can locate some threaded brass elbows, possibly 3/8" with a barbed end. Thanks gain for your suggestion.
1 - 3 of 3 Posts
