1 - 3 of 3 Posts
Does anybody have a picture coming from directly underneath a 4cyl coug? I need to see if I can run a nitrous line from the trunk into the grommet below the rear seats, then underneath the car and have it come up on the passenger side of the engine bay without crossing paths with the exhaust. Thanks. -Nate.
im sure james has pics of his shiny underside however the 4cyl part is the problem. i dont think ive ever seen the underside from anyones car in pictures. as far as installation why dont u jack it up and check it out, if its posible to do youll need to get under there anyhow...
you have a cougar right? cant you look underneath it? i could get a pic for you, but it wouldnt be a pic with the car on a lift or anything, i would just be crawling underneath and taking the pic. but thats just as good as you takeing a look. except if you look yourself, you can look from different angels...
1 - 3 of 3 Posts
