Pardon the size but I'm too lazy to resize the pic. Here is a pic of my old and new downpipes. The new one is the bigger one.
Both flanges are just 3/8 inch steel plate cut in the shape of the turbo exhaut flange and then just regular aluminized steel exhaust pipe welded to it. When I saw what my dad did to the first one I was so upset. I didn't want that flat part where the wastegate exits and he wasn't paying attention when he took it to a exhaust place to hook it up to the regular exhaust and the guy used crimp bend 2 inch pipe to hook it up.
When I redid the new turbo I wanted 3" all the way and a hump over the wastegate exit so it would flow better. My dad had the new flange cut and had a 90* 3" bend cut and ground to fit with the right angle so it would clear the ac and power steering and he took it to a welder to weld it together after he tack welded it in place. I would have prefered a smoother hump but it's decent, especially with the overall size of my exhaust. Then I cut a bunch of small pieces of 3" straight pipe in short angles, 30*, 40*, 20*, etc... so I could make some homemade mandrel bends. Tack welded it in place and had one of my dad's students who's a good welder weld it together. Even then some of the welds on the downpipe were too big so I had to grind them down. I left most of the welds on the rest of the exhaust cause I was too lazy and tired to grind those down also.
Took like two days to do that. So it would be easily removable our local Napa guy sugested we use a standard 3" triangular header flange so hook up the downpipe to the exhaust. The downpipe was the easy part, then came the fun part, redoing the rest of the exhaust upto the stock flex pipe.
That took about a day and a half. You can see the header flange so the downpipe can be removed and the rest of the exhaust doesn't have to come out. It has since been made full 3" with a 3" flexpipe. If you have a bunch of pre bent mandrel bends you won't have to do as much welding as I did but they cost a bunch and straight pipe just costs around a buck a foot.
