actually according to BAT PDFOriginally posted by: MaverickFlyer
I think BAT sells the 2 bolt ones for $55, so $110 a pair compared to $500 is a big difference. You would really have to see a huge difference in performance to justify $500!Originally posted by: fordrule
i totally understand what u mean about knowing where ur money goes, but as you also see for is selling stock control arms for $179 each, so paying a little bit more for the tubular a arms would be worth the upgrade.
didn't mean to jump on anyone on the last post sorry megail
Control Arm Assembly -handed left (drivers) right (passenger) these are complete assembled control arms with
front & rear bushings and ball joint. We have seen cars with mileage as little as 50,000 with significant bushing and ball joint
wear. The Contour and Cougar use one of two types of lower arm with either horizontal or vertical bushings. Early cars (prior
to 1998) use the horizontal type bush. Later cars could be either type, depending on the type of lower crossmember
installed at the time of manufacturer- best check before ordering. The horizontal bush arms mount with 4 fasteners (2 at
each end of the bush) and the vertical bush arms use 2 long bolts (1 per bush) through the middle of the bushing.
Control Arm Horizontal Bush (LH) K428L $169.50
Control Arm Horizontal Bush (RH) K428R $169.50
Control Arm Vertical Bush (LH) K428LA $55.00
Control Arm Vertical Bush (RH) K428RA $55.00
and from sp motorsports according to this page.
Control Arm Assembly, Horizontal Bushing,Left Hand 95-00 744-F5RZ3079B $175.95 ea.
Control Arm Assembly, Horizontal Bushing,Right Hand 95-00 744-F5RZ3079A $175.95 ea.
Control Arm Assembly, Vertical Bushing,Left Hand 95-00 744-F8RZ3079BA $57.00 ea.
Control Arm Assembly, Vertical Bushing,Right Hand 95-00 744-F8RZ3079B $57.00 ea.
Control Arm Assemblies are OE Ford and come complete with bushings and ball joints ** Control arm assemblies come complete with the front & rear bushings and ball joint. The Contour and Cougar use one of two types of lower arm with either "horizontal" or "vertical" bushings. Early cars (prior to 1998) use the horizontal type bush, but later cars are a mix of either or depending on the type of lower cross-member installed at the time of manufacturer. Best check before ordering. The horizontal bush arms mount with 4 fasteners (2 at each end of the bush) and the vertical bush arms use 2 long bolts (1 per bush) through the middle of the bushing.( is what the 99-00 cougar has per my pics)
and the set of LCA from mumm racing
so by me saying around $500 for them would be low balling adam and todds workmanship. I would guess to see them priced higher....but that is up to adam
