Status
Not open for further replies.
1 - 3 of 3 Posts
I rediscovered this on my computer the other day. I don't see this info posted here, so I'm posting it now.
Code:
Bulletins for 1999 Mercury Cougar V6-153 2.5L DOHC VIN L SFI
Safety Recalls
     TSB Number   Issue Date  TSB Title
 01S22          SEP 01       Recall - Blower Resistor Inspection/Replacement
 01S22          AUG 01       Recall - Defective Heater Blower Resistor Connector
 01S02          MAR 01       Recall - Battery Cable Routing Inspection
 01S03          MAR 01       Recall - Brake Lamp Switch Harness Replacement
 99S19          OCT 99       Recall - Accelerator Cable Replacement
Emissions Recalls
 98E04          JAN 99       Recall - Fuel Line Seepage
General Recalls
 01M04          JUN 01       Campaign - Fuel Pipe Flapper Valve Additional Coverage
 99B25          NOV 99       Campaign - Wheel Nut Wrench Replacement
 99M08          SEP 99       Campaign - Defective Blower Resistor/Wire Connector
 99L01          JUN 99       Campaign - Seat Operation, Owners Guide Update
Service Bulletins
 02-11-4        JUN 02       Aluminum Engine - New Cleaners/Service Tips
 02-4-6         FEB 02       Alarm - False Activation/Inoperative Diagnostics
 02-4-5         FEB 02       Battery - Charging Tips and Guidelines
 02-2-4         FEB 02       A/T - CD4E Harsh and Delayed Upshifts/DTC's Stored
 02-2-3         FEB 02       Engine - Aluminum Block/Head Machining
 02-1-9         JAN 02       Engine Oil - Oil Recommendations/Applications
 02-1-6         JAN 02       Wheels/Tires - Road Force Measurement Equipment
 01-24-6        DEC 01       Engine - Oil System Priming Procedures
 01-23-6        NOV 01       Engine Coolant - Propylene Glycol Recommendations
 01-22-4        NOV 01       Dashboard - Defroster Grille Lifting Out of Position
 01-20-5        OCT 01       Driveability - Vacuum Leak Detection
 01-18-1        SEP 01       Shift Interlock (BRAKE) - Inadvertent Disabling
 01-16-2        AUG 01       Brake Lights - Stay ON
 01-15-7        AUG 01       A/T - Fluid Application Charts
 01-15-6        AUG 01       Heater Core - Repeated Failure
 01-10-12       MAY 01       Wire Harness - Terminal Repair Kit
 01-9-7         MAY 01       Emissions/Computers/Electronics - Driveability Diagnosis
 01-7-8         APR 01       EVAP System - MIL ON Multiple DTC's Set
 01-7-3         APR 01       Fuel Pump - Whine Heard Through Radio Speakers
 01-6-2         APR 01       PATS System - Diagnostic Service Tips
 01-3-5         FEB 01       Airbags - Warning Lamp ON, DTC's U2017/U2018 Set
 01-1-4         JAN 01       Engine - Spark Knock on Cruise/Acceleration
 00-26-5        DEC 00       Rear Brakes - Moaning/Groaning Noise
 00-25-6        DEC 00       Charging System - Int./Ext. Lamps Flicker When Cold
 00-25-2        DEC 00       Exhaust - Sulfur Odors After Hard Driving
 00-18-2        SEP 00       Transaxle - No Forward Gear Engagement
 00-18-6        SEP 00       Wipers - Engine No Start With Wiper Switch On
 00-10-2        MAY 00       PCM - Hesitation/Rough Idle On Warm Startup
 00-9-3         MAY 00       Sunroof - Rattling Noise When Partially/Fully Raised
 00-4-1         FEB 00       Heater Plenum - Fluttering Noise
 00-2-4         JAN 00       Low Coolant Lamp - ON at Normal Operating Level
 00-1-5         JAN 00       A/T - New Transmission Cooler Flusher/Service Tip
 00-1-9         JAN 00       M/T - MTX 75 New Fluid/Service Tip
 99-26-9        DEC 99       Fuel Economy - Customer Expectation vs. Vehicle Usage
 99-24-9        NOV 99       A/T - CD4E Fluid Leak From Fill Tube/Seepage From Vent
 99-24-4        NOV 99       B Pillar - Water Leak/Windnoise
 99-23-4        NOV 99       EVAP - DTC's P0442/P0455/MIL ON/No Driveability Concerns
 99-22-2        NOV 99       Wire Harness - Terminal Repair Kit/Wire Splice Procedure
 99-21-7        OCT 99       PCM - MIL ON/DTC's P0351, P0352, P0353 Set
 99-19-6        SEP 99       A/C - Identification of Non Approved Refrigerants
 99-19-4        SEP 99       Brakes - Vibration/Inspection Service Tips
 99-19-3        SEP 99       Sunroof - Grinding/Groaning/Squeaking/Squealing Noise
 99-17-5        AUG 99       A/T - CD4E No Forward Gear Engagement
 99-17-8        AUG 99       Knock Sensor - Trouble Code P0325 Set
 99-15-2        JUL 99       A/T - Transmission Flush and Fill Tool Available
 99-14-8        JUL 99       M/T - MTX 75 Vehicle Will Not Move
 99-14-7        JUL 99       PCM - Calibration Information
 99-13-7        JUN 99       A/T - CD4E No Forward Engagement
 99-13-10       JUN 99       Headlamp - Excess Condensation Inside
 99-11-1        JUN 99       Comprehensive Noise/Vibration/Harshness Procedure
 99-12-10       JUN 99       Paint - Rough Texture
 99-9-2         MAY 99       Liftgate - Does Not Release Or Pop-Up
 99-8-9         MAY 99       Front Brakes - Groaning Noise During City Driving
 99-8-15        MAY 99       Interior Door Trim Panel - Replacement Tip
 99-8-16        MAY 99       Motor Oil - Viscosity Grade Recommendation
 99-5-3         MAR 99       A/T - Cold Fluid Level Checking
 99-4-12        MAR 99       Breakaway Outside Rearview Mirror - Service Tip
 99-4-9         MAR 99       PCM - DTC P0460 Set/No Driveability Concerns
 99-4-3         MAR 99       PCM - Reprogramming Out of Vehicle
 98-26-2        JAN 99       Fuel - Volatility Related Driveability Concerns
 98-25-14       DEC 98       Engine - Mis-marked Timing Marks On Camshaft
 98-25-9        DEC 98       Interior Trim - Vinyl Surface Repair Tips
 98-24-2        DEC 98       A/T - CD4E PCM Reprogramming On Transaxle Replacement
 98-24-6        DEC 98       Electrical - New Terminal Grease Released For Service
 98-23-16       NOV 98       Cooling System - Coolant Compatibility
Discussion Starter #2
The only TSB the dealership will do for free are the safety recalls.
The other TSBs are merely common complaints for which Ford formulated a response. That means you're going to have to pay a technician to perform the fix or pay for access to the TSB to perform the fix yourself.
I'm stickying this and locking it. If you have something to add to the thread, please PM me.
Thanks for posting this!
1 - 3 of 3 Posts
Status
