1 - 9 of 9 Posts
I cannot get the tie rod out of the knuckle, it wont budge, i have tried everything i know to try...including searching the forums...nothing helped...
I can get the ball joint to move very little.
PB Blaster isn't helping much.
so i am stuck at this point
could you be a little more specific?
The tie rod end doesn't have to come out to get the strut out. Just make sure you've disconneted the lines of the struts, and loosened the pinch bolt on the knuckle. It may take a little working to get it out..but it will come out.
Now i just need to get the ball joint out of the knuckle...
I've read that people use a 2x4...do you use it with a jack to push up on the spring?
tie rod removal tool can be had at most stores for 5-10 bucks or rented
be careful with the ball joint/knuckle or you can tear the cv joint if you let it hang
use a screwdriver and pry it up outta the knuckle.
T3/T4 60-1
put the nut on... only 2-3 threads though...
using rubber mallet or block of wood and hammer and knock it out
BTW: you need not remove the tie rod to install springs
1 - 9 of 9 Posts
