At Canadian Tire in Canada buy a compression spring 1/2 by 2 1/8. Costs about $1.50. Same spring has to be available in states as well somewhere.
Cut the spring in half.
Remove each side of existing spring from trunk lid. Insert 1 piece of new spring into each side. Keep all original parts as they are.
Now, when remote is pressed, trunk opens right up. When button is pressed inside, it may need a 2nd press at times. Still, better than not working at all.
Has been working fine for several months now and trunk is opened often.
