1 - 3 of 3 Posts
What did everyone with trubendz exhaust do about the section of pipe that mounts to the cat? Mine has slight leaks, i can feel the air. It has that slip mounting plate which kinda does a bad job of sealing, so i didn't know if anyone had a good solution that would keep it from leaking any, since you wouldn't want to weld the exhaust to the cat.
1 - 3 of 3 Posts
