1 - 2 of 2 Posts
hi...when you put my car into drive, you have to give it alot of gas to get it to go...too much gas...anyway with the traction control light on it makes this weird noise...kinda like a scrubbing noise....when you turn the light off, no noise but still doesn't change the problem with the gas?any idea? this car has made me see that buying new is the best way to go....maybe not new but running....
Sounds like you could have a bad caliper. Try jacking up each wheel and manually turning to see if one is binding. Remember parking brake off or transmission in neutral depending on whether you are checking the back or front.
Andy
1 - 2 of 2 Posts
