1 - 16 of 16 Posts
hey im buyin a set of 18's , what is the widest i can go without rubbing 225? and also what about the sidewall, 35? thnx
i am running 225s and have no problem with rubbing. it fills the wells very nicely
I have the Velox VX8s in 18s I run a 225/40/18...I also have the B+G springs that drop 1.6 give or take a few....KYB struts and not a scrub anywhere..the rear wheels tuck up nice and sweet looking...
u think i can go wit a 225/35/18? , and is ur car lowerd? how much can i lower it?
Discussion Starter · #8 ·
a 35 is less rubber....my car is lowered using B+G springs and KYB struts...The B+G springs lowered it 1.6 is what they say...I think now that they have settled some its a little bit lower. It tucks the rear wheels great...I will see if I have a close up of the rear of the car....
The only difference is a slightly smaller sidewall between than the 225/40/18.
IIRC you can go any lowering spring setup with 18's, but for 19's you need either GC or bags.
Discussion Starter · #10 ·
not TrU Ignernt...There is this chick that works up here at one of the performance shops..she has the eibach springs i believe and has a set of 19s under her car....She "says" she doesnt scrub anywheres....so who knows
i'll bet you a crisp Jackson that she does. ;)
Discussion Starter · #15 ·
and see ignernt Its a good thing we didnt have a bet...cause there is one of "our" own moderators right there with ROUSH SPRINGS...NOT COIL OVERS with 19s....I could have put em on mine but i got hella deal on my 18s....
1 - 16 of 16 Posts
