1 - 11 of 11 Posts
Originally posted by: 8BaLL
:stupid: Are u talking about NiteShading them ?
If so, you may wanna pm Keliente, hers look really good.
its basically like painting something normally. it comes in a spray can and the more you put on.. the darker it gets. the darker it gets the less light can get thru. it is however, very transparent. so 1 or 2 or 3 coats will probably not be enough. but the format to apply is the same as a normal paint job.
Like this?
Take your tail lights out. Wash and dry them off. With light, light coats, spray your tail lights (don't forget your 3rd brake light too or it will look odd) After 4-5 light coats, with 10 mins at least in between each, you can apply the spray heavier until you get your desired result. Mine is about 30-50 coats.
hey keliente , not trying to offend you, but why do you have the v tech covers if you tinted your taillights ?
1 - 11 of 11 Posts
