Over in the old school world of cast iron heads & leaded fuel, there was a phenomenon that existed where the constant contact of a hardened valve and head (valve seat) actually caused the recession of the valve seat over time. The lead in the fuel acted as a lubricant to ensure a "cushion" between the valve and seat as they opened and closed.
Fast forward to unleaded fuel. When the powers that be determined that leaded fuel was detrimental to the environment, they removed the lead. In order to keep cars' valves from sinking into the head over time, they applied a hardening process to the valve seat. Viola- Problem solved. However, in the cast iron world, cutting of the valve seats to install large diameter valves actually machines away the hardened part of the heads. This is most notable on the Grand Prix's 3.8L engine, which there are a ton of upgrades for (some running 10.9 and better). Link here.
Fast forward again to aluminum heads. Aluminum is, of course, lighter and softer than cast iron. It would appear on the surface that they might exhibit the same problem. My question is this- Are valve seats in aluminum heads hardened by any means- And, more importantly, do those of us with 3L valves and the resultant machining work have to worry about the same phenomenon over time?
