Status
Not open for further replies.
1 - 1 of 1 Posts
• Battery tray - 10mm
• Fuse box to Batt. tray - 8mm
• MAIN harness to ECU - 10mm
• MAIN harness to BULK connector on Driv. strut tower - 10mm
• Coolant resevoir - 10mm
• Ground for ECU connector - 8mm or 10mm (have seen both)
• Ground to Pass. Engine mount/ P.S. line bracket - 10mm
• Ground to Driv. side Fender well - 10mm
• Starter wire connections -13mm and 10mm
• Starter to Trans - 13mm
• MTX or ATX to engine - 13mm bolts and 15mm nut
• Torque converter nuts - 15mm
• Front roll restrictor - 13mm and 15mm
• Rear roll restrictor - 13mm and 15mm
• Pass. Motor mount - 15mm and 18mm
• Driv. Motor mount - 15mm and 18mm
• Y-pipe(s) - 2 and 3 bolt styles - 13mm and 15mm
• Slave cylinder - 8mm
• Shift cable bracket nuts - 15mm
• Shift tower bolts - 10mm
• Header nuts - 13mm
• Oxygen sensors - 7/8"
• A/C compressor to motor - 10mm
• Cam and crank sensors - 8mm
• Timing cover bolts - 10mm and 13mm
• Alternator - 10mm and 13mm
• ALT bracket - 10mm
• Half shaft bracket - 13mm
• Oil pan - 13mm
• Valve covers - 10mm
• Camshaft caps - 8mm
• Water Pump - 8mm
• HEAD Bolts - 13mm
• IMRC bolts - 10mm
• IMRC Cover bolts - 7mm
• Coil Pack bolts - 7mm
• DPFE nuts - 8mm
• DPFE bracket bolts - 13mm
• EGR valve bolts to UIM - 10mm
• UIM - 8mm
• LIM - 8mm
• Motor Mount Between heads - 10mm
• Breather between heads - 8mm
• X-over pipe to both heads - 8mm nut, 10mm bolts (2)
• IACV - 10mm
• EGR solenoid - 7mm or 8mm
• Water pipe (Pass to Driv side) - 10mm and 13mm
• Motor Hook - 18mm
• Dipstick bracket - 13mm
• TB bracket - 8mm
• TB to UIM - 10mm
• MAF to air box - 10mm
• Crankshaft bolt - 18mm
• Alt pulley - 24mm
• Idler pulley - 15mm
• Tensioner bolt - 30Torx
• Tensioner Pulley bolt - 15mm
• Power steering Pulley - 10mm
• P.S. Pump and bracket - 10mm, 13mm, 20Torx (bracket to P.S. line)
• Water Pump tensioner - 8mm
• Timing Chain tensioners - 10mm
• Timing Chain Guides - 10mm
• Clutch bolts - 10mm
• Flywheel bolts - 17mm
This guide will be updated as needed. Thanks to those who contributed.
1 - 1 of 1 Posts
Status
