Just a couple of things to think about before you follow through with it and push the car that fast, for your safety:
What kind of tires do you have? Are they rated for that kind of speed? Many high-speed solo accidents occur because the tire was not meant for the speed the driver was pushing the car.
Make sure the road you drive on is free of any bumps and so forth.. even smallish bumps can practically become jump ramps at high speed, causing a possible loss of traction and control.
That's pretty much it. I won't bash you for wanting to go fast, just make sure the car is prepped to do it and do it at your own risk.
And DaButcher-
The non-sports package has a speed limiter at 115, the sports package has no limiter; drag + your available power will limit you. I've hit a shade higher than 132 before (136). Weight in the car makes a huge difference at that point in acceleration ability, as do aerodynamics, humidity, etc, etc. IIRC, we're drag limited to about 143 in optimal conditions.
