You could in a sense, it bolts to the mtx 75, so mounts wouldnt be a problem. Only thing would be engine wiring, which probably isnt much different. And the big thing is the ecu, Im not so sure the focus ecu would work too well on our car.Originally posted by: Josh125XR
I got one also. I want to keep the cougar for a long turm but I'm not to happy with the VCT Zetec engine so will there be much trouble to drop in the Focus SVT 2.0L engine? Cause this I4 doesn't have much balls So I figured Y not just install that instead of the 2.5L V6. I was just asking cause I wonder if that engine works with our MTX-75 transmissionas well. Thanks
its since been discovered its the same, only the atx and mtx subframes are differentOriginally posted by: TURBOZETECOUGAR
i also heard that the subframe is different from 4cyl compared with the 6 cyl....good luck on that
i was asking this because awhile back i posted in the 3L section and someone said i couldnt because of the subframe difference mentioned in one of the above posts. i was thinking of doing this a few months ago but after reading the whole 3L forum, i posted the question and they said it would be impossible. here is a link to that post.Originally posted by: Ness1216
yes it is, but if you have to ask then its not a project for you.
