I finally pulled the stock upper, cleaned the lower, and installed the SVT upper. Everything went well except for the bracket. The stock bracket had three bolts, one bolting to the tb and two to the upper. The SVT has two to the upper and the third one looks like it should have a hole on the TB like the stock one did, but it doesnt. It lines up with the TB bolt hole that attaches to the upper. So I pulled the bolt and tried to bolt the braket with the TB to the upper, this just caused it to sit crooked. Do i need to put some washers behind there or what?
After cutting my thumb when disconnecting the cc cable, I didnt try to do the throttle cable. Is this simple to replace, or will it be a pita?
Also what color are the stock 17# injectors?
Thanks
Thanks
