Does anyone got any good layout ideas for 3 12" subs and 2 1200 watt amps and not in fiberglass, in wood and carpet and kinda not all the hatch :tongue:
NO.lol The only set up I have seen with 3 subs that were all wood was some members on here that was in the shape of JL. I think they were 10's and it took up the whole trunk.Does anyone got any good layout ideas for 3 12" subs and 2 1200 watt amps and not in fiberglass, in wood and carpet and kinda not all the hatch :tongue:
Almost every car amp I have used works fine being run in parallel what you have to look at is that you are presenting the right load to the amp, there are usually different power ratings for 4ohm 2 ohm etc. my amp actually is advertised to automatically sense load and put out the same power regardless stable to 1ohmAnd every amp manual I've ever seen says not to hook two or more subs up in parallel cuz it won't work at all.
