1 - 14 of 14 Posts
Ok i have no clue what these are called so i couldnt search for them. But basically i need to konw how to remove the stripe thats on the side of the coug. its white and goes completely front to back. Reason im asking is coz i came to thinking.. if i get z3 fenders.. there wont be astripe there.
thanks
sure..
basically.. i didn't want these stripes but when i got the car.. this is the one they had.. it was take it with it or wait another week till they found a coug with my specs W/OUT the stripes.
oh... pinstriping... eww... hmmm...
Good Luck!!!!
Actually, if you're going to get a shop to paint and mount the fenders, they can take it off easily (for a price, of course). Otherwise, you might want to try the technique for removing the lettering from the rear... hair drier and fishing line (remove lettering)
wow, that's the first time i've seen that on a cougar. it came like that from the dealer? :banana:
you could also try soaking it with WD-40 or similar lubricant instead of the hairdryer. that's how i removed my badges.
goodluck dude!
<sigh> yea thats how it came from the dealer.
Just a quick warning...I used to have a luxurious Ford Tempo, and it had the beautiful pinstripes. (I am sure we paid extra for them...) Anyway...One day I was washing my beauty with our power washer. It started to take the pinstripe off, and when the car was wet it looked like it was coming off without a problem. I tried taking all of it off, but it wouldn't take about half of it off. When it dried, the parts that were now missing the pinstripe turned a dark brown/black color.
Since it was on the Tempo, I didn't mind. But if it were my cougar, I would probably have made a poopie in my pants. Just a thought. The car was a 93, so maybe things have changed by now. Just wanted to let you know.
Take it easy.
Since the Z3s are causing the problems, test everything out on the front fenders first. This way, if you mess up or a technique doesn't work, you really ain't loosing anything...
Just a thought.
my car had a pinstripe and so have many other members cars.... bust out a hair dryer and heat it up a little... start peeling... its gonna come off in chunks cuz you are gonna work a section at a time... once you peel it all off grab a rag with some 3M Vinyl and Adhesive Remover and your residue will be gone in minutes with no actual hard labor.. Plus its safe for paint... I removed mine then sprayed some detailer over it and I have no line difference or anything.. all you need is a little patience and the right tools/products
Discussion Starter · #10 ·
wow thanks crispy! do you think goo gone would work?
that's how i got mine off.....but i didn't use the hairdryer. i just pulled and it came off. then i used the 3M adhesive remover to get the sticky crap off. i think goo gone should work also, just be sure that it won't hurt the paint.
as for pinstriping, what i understand is that it is a dealer option. the dealer puts in on...it doesn't get put on at the factory.
good luck!
I know bug and tar remover took off the dealer logo *residue* off the back of my cat. The rest was just peel and eat.. er throw away. If all else fails, borrow a heat gun - my former Y2k1 honda had pin stripes - I made the dealer take those fugly things off before I would take the car.
It took myself, my salesman, and the kid who was detailing the car for me when I bought it about a half hour to remove the pinstripes. Mine must have been recently put on because although they are a pain to get off, they didnt leave any lines. Just be patient with them and they will come off. Grow a couple of fingernails in the meantime to make your job easier. :)
I definately recommend the 3M Vinyl and Adhesive Remover... its great... no rubbing or anything... just a simple wipe and its off... All my experiences with Goo Gone or WD40 have been me bustin some severe elbow grease so I pitched it all and invested in more of the 3M goodness.... :)
1 - 14 of 14 Posts
