i just bought james' GC's with ST 200 struts, which strut mounts do i need to get them to work on my 99?
thanks
casey
T3/T4 60-1
you might have an issue in the rear... if i'm not mistaken the 2001 kit has slightly different rear top perches.... i can't remember the exact different but when i first seen them i though it could easily be made to work on 99-00 cougars also, take a pic of the rear perches and post them here... i'll tell you what needs to be done....
The only thing i can think of that may be different would be the bushings or the aluminum hats. In either case those can be ordered from GC. Any other difference would be with the stock rear strut mounts themselves.
They look the same to me. Give me a close up of the metal hats, and where are the bearings and bushings at?
Discussion Starter #8
which part is that?
