i think you should ask this in audio electrical... to answer some of your questions..
you will have to pull your headlights out and disconnect them..there is three screws to take out to remove your lights you will also have to pull the front grill out too...check your owners manual for headlight bulb replacement...that will get your headlight housing out of your car and then you can open the back of the light and have access to the insides...
depending on how your strobes look you can place them in the spot up top of the light where the sun sensor would go...if you have the "U" shaped strobes then you will have to find a spot for them..post a pic of your strobes...
you may have to open your lights right up by heating them and poulling them completely appart so you can place the strobes infront...
also what year is your car and what style of headlamp assembly do you have??
You may want to consider putting the strobes in the footwells up front. It'll be something cool to play with at night, and you don't risk getting in trouble with the po-po quite as much. Just an idea.
As far as the wiring, http://the12volt.com/ has some good reading for you. Make sure you've got a fuse and a good ground on whatever you did, and make sure any wires are secured away from your feet and all the pedal. Also, wire up the switch somewhere temporary until you're sure where you want it. Ergonomics are important: put it somewhere easy to reach, but not someplace you'll accidently turn it on/off.
