1 - 2 of 2 Posts
Ok...im just posting this as an fyi because every post i searched no one knew the right colors of the speaker wires
the wires that come out of the front door speakers (on my cougar) are white and grey. After doing using a voltage meter on the ohm setting i figured out that:
White: +
Grey: -
this is the same case on both doors (in my case at least)
once they get to the back of the headunit, the colors have changed dramaticly. and you can test them by using a battery, and rubing one wire on the pos, and another on the neg end of the battery. if one wire if from the pos of a speaker, and the other from the neg of the same speaker, it will make a crackling sound when you are rubbing them to the battery. just incase anyone wanted to test lol.
1 - 2 of 2 Posts
