So a while ago I installed a rear sway bar. It would squeak over every little bump i hit. I realized I forgot to grease the bushings. So I greased 'em up with plenty of poly grease I picked up at autozone. The noise went away. Now i'm getting another squeak maybe a week later, but I'd say it's more of a groaning sound. It's not as bad as it was originally, but somethings not right.
Is there something that could have fatigued or needs lubed since I installed the bar? I'll be replacing the stock suspension with over 97k soon enough.
Btw. I'm using the poly bushings that came with the BAT bar.
Well, I installed the Roush sway bar and used the Energy Suspension poly bushings. I've found that depending on the grease you use, it washes out easily and begins to creak again. I found a product called Sylglide or Silglide (I don't remember the spelling) that works really well and doesn't wash out quickly. I still need to reapply every few months, but it's lasts much longer. If you can't find that (comes in a big toothpaste type tube) then I would try marine grease since it's more waterproof and resists getting washed out better than some other automotive grease. I would try that and if that doesn't work then I would say it's something else and not the bushings.
ok it took me forever to get every creak and groan out of my suspension.
so your sitting on tired stock with a new sway bar? Are the sway bar end links original? Mine were in horrendous shape when I took them out at 60k
The end links are original. I believe Bradness @ CEG sells new ones, correct? They look ok, well, i'm not sure what i'm looking for. They're attached, in one piece, and appear to be doing their job.
