1 - 2 of 2 Posts
F
Guest
I am currently trying to track down lowering springs for my 02. I would prefer to buy springs specifically for the 01-02, I do not want to have to modify anything by cutting or adding. Does anyone Brands and part numbers, I've tried the usuals, Eibach, Intrax but none list for the 02. If you can supply part numbers that would be even more appreciated. Amount of drop isn't that big a deal just as long as it closes the gap a little bit.
And I'm not in the market for GC's because I plan to do the install myself and don't want to spend more than the $200-$250 for the springs. Fixing the house is top priority at this point.
Thanks in Advance
Check the Suspension FAQ, and you'll quickly see that GC is the only 01-02 application. You need rear seats for 99-00 spring installation, so it's not really all that bad. The part numbers and information are located in that thread.
1 - 2 of 2 Posts
