I have had issues with my speedo recently. It kicked a CEL for malfunction in the VSS, I replaced it. Now I havn't been able to get my speedo to work again. All my other gauges work like they should, just not the speedo.
Now when I hook my scanner up to it, I can stream it. Showing the vehicle speed through that. So the VSS is sending signal to the PCM. From the VSS it feeds into the PCM via pin 58 on the main plug, leaving the PCM via pin 48 (white/black wire). I have signal going into the PCM, but not coming out?
More info: The cluster recieves the signal for the VS through the black plug on the back of the gauge cluster, pin 7. Also a white/black wire.
I have a total of 3 cluster's and have installed them all to make sure it wasn't the one in my car. To my amazement, none will register the speed.
My thought is to tap the wire coming off of the actual VSS and send signal directly to the cluster? And see if I can read on the cluster that way. Thoughts of doing so?
