You can buy the stainless steel braided hose kit at just about any auto parts store. (I've even seen it at Pep Boys!) The most popular one is made by Spectre. It is fairly simple to install. What you do is:
1. REMOVE any of the hoses you wish to cover with the stainless steel braiding, or at least one end of them.
2. Measure out the braiding in the appropriate size. (For example, if you're covering 10mm hose, use the 10mm braiding!)
3. CAREFULLY slide the braiding OVER the existing hose.
4. Use masking tape or electrical tape to WRAP the ends of the braided hose together while you are working with it. (If you don't, the braiding will fray and you will be SOL!)
5. Use the supplied hose-end fittings (basically glorified hose clamps) to secure the ends of the hose.
6. Repeat this process untill all the hoses you wish to cover are done!
If you have further questions, or are in need of more detailed instructions, please PM me or post on here!
Good Luck!
Charles
