Guest
·Well the other day I decided to replace my main Injen piping with a larger diameter short ram pipe, so I hit up ebay and picked up an SVT Contour short ram. This company sent me everything! I mean everything! Even a MAF adaptor that matched the quality of the Injen if not better. However there was one major difference, the piping actually matched the diameter of the SVT Throttle Body, which makes sense since after all the short ram is designed for the SVT Tour. I also purchased a KKM intake which came with a fairly large MAF adaptor. After some modification and making the holes bigger to fit the bolts up to the MAF I had completed the install. An eyeball look down the intake pipe shows a perfect match from the filter size to the throttle body. I reset the ECU and decide to go for a brisk drive, and WOW what a difference it made, seriously. The car seemed to wake up a lot more on low end, and throttle response was greatly improved, and I notice more pull on top end, especially in second. Quite honestly, this custom built short ram felt a lot better than my CAI. I havent hit the dyno, but I really dont plan on it, but I do plan on hitting the track soon to see if any improved times come up.
Cliff Notes: For those that have an SVT TB and piping that doesnt match the diameter, I highly reccommended matching up the sizes. Huge improvement on low and top end. A lot of short rams and CAIs I have seen, have at least one section of piping that doesnt quite match up to the rest, which I think may be hurting performance. All of this is speculation and theory but it seems to hold true on the butt dyno.
If any of you all are interested in purchasing the short Ram I did, PM me for the contact info and for the ebay link. The short ram can be bought for 35 dollars which includes a MAF that will fit.
