How in the world do I get this off? I want to put on an aftermarket one but I can't seen to get it off. I don't want to twist hard cause I don't know if anything will break and how do I know if the new knob is compatable with the reverse lock thing. You know how you pull up to go into reverse?
Twist it Hard (Lefty Loosie)
Just take out the reverse lockout.. There's no reason to have it (IMHO).. It's impossible to put the car into reverse if you're going faster than 5mph.. The shift boot is held onto it with a zip tie.. just cut the sip tie off, and pull the reverse lockout off..
the gear will still be there.. just toss the shifter where reverse is... you just won't hafta lift up the shifter first...
