Running LEAN...WHY!?!?!
My problems are well-documentes in this forum, but I'll summarize.
Pinging. Serious bog and intake backfire when starting out from a stop. Missing, bucking, and jerking when opening the throttle at less than 2000 RPM's. Shuddering while accelerating on the top end.
Since these symptoms started, I have tried MANY, MANY things to fix it.
New Autolite platinum plugs.
New Ford Racing wires.
New coil pack.
New fuel filter.
New fuel pump.
Fuel Injector pressure sensor replaced.
Last weekend I had the injectors cleaned thoroughly with a pressurized 3M treatment, and reset all the codes. We ran a fuel pressure check, and found a steady 30 PSI at idle, and a 40 PSI spike when blipping the throttle. I was getting a CEL, and the codes were for lean condition, lower O2 sensor, and IMRC stuck open. I checked the IMRC; the butterflies were closed at idle and partial throttle, so I think the IMRC code was a one-time fluke. The lean condition code is a given, being how the thing nearly blasts the filter off the intake every time I take off. The lower O2 sensor has me stumped, because I have a MIL eliminator on that.
To this point, nothing has even touched the problem. I only have a few things left in the fuel delivery system that have not been replaced: injectors, MAF sensor, and IMRC.
I don't think the IMRC would give the shuddering top-end acceleration as well as the low-end intake backfires, so I'm pretty much ruling that out.
I have thoroughly cleaned the MAF; although if it is truly bad, that wouldn't fix it. Maybe.
My most likely candidate is a bad injector or two, not giving a strong enough pulse when the throttle opens. So I'm getting ready to replace these.
Before I incur the expense, does anyone (DanG, I'm looking in your direction) have any ideas about what could be leaning this thing out? Would a bad O2 sensor cause this kind of trouble? Would a weak battery cause it (I think my battery might be compromised since my last alternator failure a while back, and the cold weather is axascerbating it)?
How about the timing chain tensioner? I guess a loose chain would affect the timing, but wouldn't it make a racket? Is there an easy way to tell if your timing is off?
Sorry this post is so scattershot. I'm just running out of ideas (and, not to mention, money)...
Any thoughts, opinions, or help are MUCH APPRECIATED.
**Fix in the last post...**
New coil pack.
New fuel filter.
New fuel pump.
