It connects right next to the rear wheels
You have to jack up your car, remove rear wheels, remove the 4 bolts...2 are end links...2 are the bolts on the bar/bushings
You might have to drop ur gas tank....and then install all with lotsa grease on the bushings
I am waiting to put backing plates on mine...so the bar will not brake the stock brackets after a long period of use
