Well, the car insurance is over and I already have the garage full of junk for the move, so I have no car ...
My action plan is:
Work in :
Install the new IACV
Repair the IMRC
Mount the throttle body that I have improved while waiting to get the 60mm
Design a cold box for the new air filter
Get the elastic supports of the exhaust pipe that I put some generic ones but they can be loosened since they are a little wider.
Does anyone know the reference of the originals?
Daydreaming:
I've finished watching B3NN3TT's entry "2021 Autocross build" and I'm still dreaming
Those wheels
That interior that already looks like a racing car ...
And that way to improve the grip of the rear axle ...
B3NN3TT I did not want to tell you anything in your post in case it was something incomprehensible with the corrected translator English I use, I didn't want to spoil your post
But how do I know you read mine I ask you.
I have bought the 300mm Focus ST front discs but I see that you use special calipers, can you recommend a kit that can be easily adapted?
Can you tell me which reference of D2 shock absorbers you mount?
After having driven the car on my way to work these days, I draw the conclusions that the car is very fast and stable at medium-high speeds but in a slow corner circuit it is heavy and with a bad distribution of weights, the rear axle is bouncy And the front has all the work for which regulating the damping, lightening the car and putting weight behind is important.
And already put to dream of a version to NOT circulate on the street
That every day I have more clear in looking for a second cougar that is better than the one I have and the one that is worse to use for this ...
Sports seats far back, as long as my legs allow, maybe I need to lengthen the steering wheel.
Remove all the interior, upholstery, plastics, ... including the dashboard and mount a display with the ODB2 data
A safety cage structure that reinforces the damping struts
Fire extinguisher and battery in the trunk
A small, homologated gas tank in the trunk
Change the bonnet for a fiber vented one
Change crystals for polycarbonate
Remove from the engine everything that is not used: air conditioning, heating ...
Could we go down to 1100kg?
The good news is that such a car does not need to be legal if it is not going to be on the road so it would need a trailer.
The downside is that going on free days at the racing circuits is not cheap here and its speed is medium high where power and braking work is more important and it is a different tuning than that of the slow corners ...
The good thing is that the road I use to go to work is included within the sections of the "Rally Costa de Almería" The bad thing is that to participate you have to have your kit and car approved with the federation regulations and of course that is another level of economic expenditure and driving as well as cars suitable for that use, they are usually very light and more tuned to control lateral slippage than to avoid it.
In the end, so much law, so much homologation, so much regulation, only means that normal people do not participate in motor sports, and fewer people follow them, which is why they tend to disappear ...
And day-to-day life on normal roads is not the place to do unsafe things either ... you can't "release?"
In that and other things you are very lucky, Autocross is something great ...
Citroen AX, Rally valle del Almanzora 2020
This is not me, these are the same roads I use to get to work. If it goes faster than me
