E
enahs
·Guest
Can i do this myself? I want to see if it will come back on. I think i fixed the problem.
Thanks.
Thanks.
Originally posted by: Fett
If the light comes back on after you reconnect/start/let idle for a while, then you didn't fix the problem.
I agree having a scanner is nice but, the statement that the codes are kept and recorded unless you manually reset with a scan tool is not correct.Originally posted by: naynay
Really...... the best way is to clear the code by using a code reader. The code will be recorded and kept unless you manually clear it. You can find a nice code reader on Ebay that can read domestic and import vehicles......those readers really come in handy when your stumped on a cel.
Doing the battery disconnect/reconnect often is not recommended but...... it does speed things up.
Let it out Fett! Let it ALL out!! :biggrin:Originally posted by: Fett
:::bites lip:::
