i tried searching whem i originally posted, never found it. All you basically have to do is remove the plastic engine cover, and IMRC. And unplug the big plug going into the coil pack. Spark plug wires take 1 minute. The replacements you buy are already cut to length and have the number on it (1-6) which corralates(spelling) to which spark plug that goes too... Just replace one wire at a time, while replacing that wire inbetween replace the spark plug. To remove the spark plug, just need 12" of extensions and a spark plug socket, which is a normal deep well socket with a rubber ring inside to "grip" onto the plug when you move it out
All tools needed:
3/8" ratchet
2 6" extensions
1 spark plug socket
1 10mm socket (for engine cover and IMRC)
6 spark plugs
spark plug wires
spark plug gapping tool
Some spark plugs you buy come pre gapped. I do not think the autolite double plat do, so you will have to gap them yourself, really easy. When i first changed my plugs, i was a total beginner and noob, and took me half an hour. I can now change them in 15 mins flat.
