How exactly do you go about replacing one of these? I think mine is on the way out.
T3/T4 60-1
2 bolts, 1 electrical harness, and you pull one hose off (no clamp)
yes it's that easy... best part is, you don't need to remove anything else as it sits right on the side of the upper intake manifold
What is a IACV?? How often should you change it and how much does it cost??
El Mucho Post Whoro
IACV == Idle Air Control Valve. It is an emissions control device (basically) that slowly decreases the amount of air going to the engine to help burn off excess fuel when your throttle plate snaps closed (after you take your foot off the gas). It also controls the idle of your engine.
You should only replace it if it's broken. You will know when it's broken if it makes a 'moosing' sound like a foghorn, or possibly if you start your car and it tries to idle but dies immediately.
I believe the part is about 100 bucks from FordPartsOnline.
