Maybe someone can shed some light on this one...
In the 2001 headlights, there are two lights in the innermost part, the high beam, and this little 'bulb', which is supposed to be a parking light. Unfortunately, the manual says that it should pull right out, but it doesn't - you can rotate it until the cows come home, and it still doesn't work.... does anyone know to remove that little parking bulb - it's like a little nightlight bulb :)
Thanks in advance!
what i did was took off my healamp assembly completely, and you have to get some small fingers in there and you have to get it at an angle or else it will just turn forever. the bulb size is 168/194.
Damn... I was hoping for a simple fix... looks like my gf is going to have to do some work :)
Originally posted by: ladz
it does pull out...it seems tough, but try wiggling as you pull....
i took mine out and threw in some 194 LEDs
Finally got them out - thanks everyone for verification of all that pulling :)
I put some more blue strobes in there - fit great, and look even better (can't wait to see them at total darkness)
